Some quick answers:
1. I have not heard from any E36 drivers who would run with the SIR, so the plan right now is to delist the E36 325 and have it moved to ITR at 2750 unrestricted.
2. Evan, we looked at putting the E36 M3 in ITR but it moves the target rwp too far up. The class is maxed out at the 222 hp Z32, the S2000 (at 240 hp but pretty maxed at that displacement and with little torque) and the 968 (with again little room for improvement). The RX8 and the BMW S52 cars (M Coupe/Roadster/M3) are probably a little too much, if not a lot too much, for the class.
3. The target stock crank hp for the class is in the 190 to 240 range.
Hope that helps.
Jeff [/b]
Jeff, hope you plan to eliminate motec and such from ITR.
