If I am not mistaken I believe my car has drums, but I will double check tonight. I will also try to post some pictures this weekend if I get a chance. How difficult is it to remove the dash in a civic? We are going to be rebuilding part of the roll cage and adding a bar inside the dash that will connect both front down tubes on the cage, so the dash will have to come out. On the roll cage there are some stickers, I assume inspection stickers, do these have to stay on the cage? I will also be adding some additional bracing on the cage. One area that needs a reinforcing bar is from the roof halo to the main roll bar and it will attach where the stickers are located. We will also be repainting the interior and cage so I need to remove them for that as well. Can someone help me out here?
Well I am the cage guy, I am a J.H. shop teacher so I will be making the modifications myself. A friend of mine ownes a limo shop and has a hydraulic tubing/exhaust bender that I can use.
So where exactly would you connect to the firewall?
I also have been looking at the pictures in the Tech Center of the CRX build. Is everything in those pictures ITA legal as far a cage mounting/attachment points, the welded in front strut tower brace, etc? These are great pictures and give me a lot of ideas for my car, I just want to know if they are legal before I copy.
Read the section on cages in teh GCR first. THings may have changed since that build, but teh good book will save you. ;)
