Because you can now put the 13B into any Mazda chassis. In a RWD application it would be the same 2680 as the ITS-spec RX-7 already allowed. More options, albeit still on the 'safe' side for weight.
So they lowered the weight by 26lbs to adjust for the extra RWD % that got added so the numbers would match up with the 2680.
Mazda with a 1.8L 180whp piston engine - 2515lbs
Mazda with a 13B 180whp engine - 2680lbs
