One of the issues with getting the car classed is folks don't understand it. They see 5L and run away, and V8 and run away. They miss the fact the cam, heads, and intake on the 94-95 models came from the 5L in the Thunderbird/Cougar and don't flow worth a damn. And in IT trim there is precious little that can be done - you'll have a set you back in the seat torque monster from 2k to 4.5k, then the party is over.
Power will be low compared to the 3L screamers in the class. It'll be a fun driver though, but when the time is right I'll work with some of the folks here that know Ford motors and write a proposal. The car won't upset ITR, but like I thought, it'd bring more people into ITR. And, it will be a cheap car to build and bullet proof - reving to about 5k will be easy on the motor and components, although it might go through some pads. I'm willing to try it though and maybe, just maybe, prove the naysayers wrong on the brakes. Might could be a good point and squirt car at CMP, if it can be taught to turn in crisply since the torque will get it off corners.
