Originally posted by GregAmy:
Using your logic, and comparing this length measurement to time, the minimum amount of jail time someone can serve is zero years, and in your example the maximum is 5 years. If I'm sentenced to "up to 5 years" in jail that means I get zero to five. In IT, if I can run "up to 15 inch" diameter wheels that means I can use anything from zero to 15.
BS... In the example, we started with ZERO to 5 years of jail time... In the IT example, we are starting with 13" or 14" wheels... It's your presumption that get to start with ZERO diameter that is flawed... We start with what is specified...
Comparing this length measurement to your currency example, the minimum amount of money I could spend is zero, the maximum $100. Just as that item could cost me "up to $100" - which means within a range of $0 to $100 - I can use "up to 15 inch" diameter wheels - which means within a range of zero to 15 inches.
BS again... see above...
Your judgement is clouded by the base premise that there's a starting point. There isn't.
I'll make a note of that.... "Note to self: Spec line is no longer valid, according the IT.com as the numbers on the spec lines resembling 13's and 14's now are really ZEROs..."
[list]You figure it out...
[list]
My perception is just fine... no clouding here... I definately don't agree with you, but that doesn't mean I'm not seeing things as clearly as ever...
But do as you will...
<font face=\"Verdana, Arial\" size=\"2\">And for you to insult the intelligence of the folks on this board for calling you on it (\"You guys are out of your minds if you need more clarrification...\") is unproductive and does nothing for your brownie point count...</font>
"unproductive"... Yah, that about describes this...
As for earning "brownie points".... http://Forum.ImprovedTouring.com/it/rolleyes.gif
(PS: OK, so I responded one more time... so much for good intentions... )
Darin E. Jordan
SCCA #273080, OR/NW Regions
Renton, WA
ITS '97 240SX
http://home.comcast.net/~djjordan/Web/DJ_AV1.jpg
[This message has been edited by Banzai240 (edited January 31, 2005).]
