I have a tendency to try and explain that I understand both sides of any argument when I engage myself in it. the construction is varied, the materials are varied. the techniques and design of the braces will vary. there are too many things to control that cannot be controlled tightly enough given our club type structure.
the point, I hope, was that improperly installed they are dangerous, and that the mounting mechanisms already inherent to the seats, with which they were approved, should be BETTER inspected and possible legislated before additional, uncontrolled fabrication is brought to bear.
there's a story that sticks out in my mind. a veteran, legendary chief of tech from the buccaneer region and a guy who was still moving up the scrutineering ladder were doing an annual on a car at savannah. the new guy wanted to fail the seat because it was loose. he insisted that they add a back brace. the veteran signed off on the annual anyhow because the seat was FIA and that was all he needed to see. both of these guys have annualled hundreds if not thousands of our cars. and they were both missing the problem. the seat was not mounted adequately within the current rules. overlooking the poor installation because of a cert that has nothing to do with the success of the mounting, or to insist that additions be made beyond repairing the actual failure when said addition is NOT required, seems to sum up the SCCA approach - do nothing then over react to failures of the nothing. the tech sheds are full of good, concerned men and women. many of them are very smart, but their backgrounds vary and their foci or pet issues vary and their competence is not well regulated - the inherent issues within a club of volunteers.
this rule change is dangerous due to a number of factors, most of which are simply out of the reasonable control of the club.
tom91 - I get that you think the kirkey seats of the world should be allowed to run without a brace if the sparcos are. fine. just show me where FIA, SFI, NHTSA, DEKRA, or another worthy organization has crash tested it successfully without a brace and it's all good. most Al seats are structural garbage. sorry.
