http://72.167.111.130/forums/showthread.php?t=23691
Is the survey, IMO it didn't have enough choices (or wasn't clear enough.)
I think it should have been more like this:
1. Leave rule alone, no RR, Double Adjustable Only
2. Allow RR for cars which had it as OE (only if you use OE shocks), DA Only
3. Allow RR for cars which had it as OE (allow aftermarket), DA Only
4. Allow RR for all cars, DA Only
5. Allow RR for all cars, no restriction
The way that original survey was worded "Any damper may be fitted," was a sure way to get people to vote against that option. It _sounds_ too unrestrictive. It's important to restrict the number of adjustments, as that will control costs. I also believe there should be a rule that "No shock that was ever offered as a 3 or 4-way damper can be converted to 2-way."
That would make sense. Time for a new poll?
