Yea, absolutely! The stage that I was talking about had less rigidity, and it led to people championing parts of it. And others negotiating adders to "pull back" when they weren't onboard with earlier decisions in the math. It was rare that it went down like that, but there was one instance where it was way too push/ pull. (I was guilty of disagreeing with earlier parts, saying so, not getting them backed down to reasonable levels, then hedging later adders to try and keep things "reasonable" in the end.) In general, I liked our direction, but didn't like things like that, and it bothered me that I had to explain to the members how we arived where we did. So a push of mine was to standarize as much as possible, and create methods to track and regulate when and how we deviated. Or, put another way, i begged Kirk to join!
IF v2.0 had been adopted, it still had flexibility, but it assigns votes and it gets signed by the authors of the opinions, and records are kept of outside data. While it still has SOME room for hanky panky, shining sunlight in on each decision makes it much harder to veer from the proper path.
I'll say this again, after being inside the darkened smoke filled rooms of the committee, I want the windows open and the sun shining in. IMO we have far less to worry about if every bit of discussion was public than we have from releasing only bits of info.....when you know you are being fed 'manged information" you wonder what you AREN'T being fed, and that leads to suspicion.
People on the inside object and say that if what they said was repeated, they wouldn't say it. Well, I went 5 years on the boards, and i can't remember saying anything that I really worry about being repeated. Seems to me that if you can't say what you are thinking in front of the membership, then maybe that should tell you something.
