In response to Jeff's question - I see IT as #2, it's prod-lite.
everyone FAST explots loopholes, pushes definitions, or flat out cheats if they can't reach the front honestly, which only a few cars per class can do. then some of those guys do the same. there's no enforcement that is easy to do, so much of it goes under the radar even though it fails the sniff test, smelling alot like a $15k SS build.
as for ABS - keep it out, way out. I don't want to rely on the same engineering prowess that suggests a chain is a perfectly good torquing limiter / engine stay rod to defeat a modern stability / traction control / ABS system correctly so that it works as ABS only. until megasquirt has an ABS module, I will continue to think this way. probobly will after. if we need to move away from stock brake master cylindders, I say why not? we already allow open hydraulics from the MC to the caliper/wheel cyl. might as well allow a pedal and twin tiltons - it's not much more expensive. do it on a line by line basis. and yes, I know this adds to prod-lite.
wheels - stock should be fine. I don't give a rats posterior if car X came with super-secret limited edition 3.5lb 17x10" magnesium superwheels from mars. if it's STOCK (not dealer installed and referenced in the appropriate service manual) then it's legal. if someone just wants a cheap source of 6.5" wheels they can popund sand, though - this is an expensive game, deal. if we worry about trim levels, call out the allowed trims on the spec line (and/or use the term "standard" and define it as NOT special or limited edition equipment):dead_horse:
IT is already allowed to run in ST (a very good, clean rules set, I think). might as well start looking that way gentlement - it's the inevitable future of this snowball unless we stop it with a BIG rewrite that's bound to bunch a lot of panties.
