Steve, this is an unfortunate truth, as well as good teams or good people with the most money win. It has been this way from the beginning. Example, if I have a budget of say, 10k for the year and you have twice that and can afford more & better tires, more dyno time, track time, etc. The chances your will beat me will be certaintly be in your favor. So even with a flashed ecu, if you spend 4k on dyno time the chances you will be able to squeeze more hp out of your engine and ecu than I will. The only inequity of the ECU rule right now is allowing the top money spenders to be allowed to stuff their ecu boxes for hugh sums of money that most of us either can't or refuse to spend. Like the old shock deal, this will be unfair to those who have spent the money. I'm for opening the ecu up but really don't care which way it goes as long as current ecu rule is changed. No matter how much money anyone has, we should be understanding enough with the rule writing not to slam any group of people. In the end the good drivers that have the money will probably still beat us,...........just not by as much. :D
Dan
Thats why I see the money deal in all this as a no brainer. You will make it cheaper if you do not need to stuff the box and you allow a cheaper ECU to be used that does not need a rocket scientist and $10,000 to install. You will save money if you do not have to defeat the factory code. I saw your latest times for Mid Ohio--you get the job done fine. :eclipsee_steering:
