Originally posted by GregAmy:
Ok, so if someone replaced the radiator in their ITC New Beetle, and the replacement radiator didn't need a reservoir, could you use the reservoir as your windshield washer bottle, removing the washer bottle by forcibly prying with your switch stalks, then use the broken switch (uh, sorry GAUGE) parts as gussets in your rollcage (making sure they meet the minimum diameter) then fabricate an intake restictor from the leftover material (verifying you go UP TO but not less than), all the while ducting "under hood air" to the modified ECU (but not the wiring harness) and using the MoTec system to control your turn signals (which will be turned off anyway so as not to be functional), simultaneously grinding your G camshaft to fit into a Nissan 510 and possibly breaking the pasenger side door glass, would you actually be cheating or simply interpreting the intent of what your mother told you when you were a small and impressionble child wihout a threaded shock body...
