Well, it appears in the same source as the same number over time as well. Ignoring "all over the place", because that's not relevant, right?
Agreed, something has changed. But, if the ETKA has, as reported, DIFFERENT power numbers but the SAME base number in the SAME revision...doesn't that strike you as an error? And if there's one error, then I think I'd want to KNOW and understand WHY the numbers changed. Again, if it changed because the downpipe changed, then using the higher number is unfair, as precedents and the op manual require the lower number be used.Quote:
However, the fact that the ETKA has changed, especially after production has ended, is very interesting to me. These things don't "just change" ... somebody changes them. And believe me, with big companies and big volumes of data, they change with purpose, not accidentally. So in my mind there's something significant about the updated numbers. I suspect that if you buy a KX crate motor now, it has 120hp. What's different, I have no idea. But that the number has changed is a big clue that SOMETHING has changed.
No, I think there IS something to prove...you're accepting one over the other. Why? One is consistent, the other seems to give multiple choices. Which are you choosing and WHY?
Hey, maybe it' is a trigger that results in some more research, and the research shows a different head. Or a throttle body or cam, or who knows what, but BAM, you now have the reason. Great. But without finding WHY the numbers vary, it's basically 'picking" one because you 'feel' a certain way.
And if that's the case, fine, but it needs to be codified so when this situation arises again, the course is clear and cars are classed consistently.
