GRJ
Exactly, K. Signal stalks are switches just like toggle fuel pump, ignition, etc. switches. And again I ask what rule are you using to install those switches. And if you are using the rule, which I beleive you must that you can add, replace or remove gauges and instruments then you must allow removal of turn signal stalks.
I'll be as clear as possible - my car starts with the stock ignition key and has all of the switches for the required parts and even for the AC, which has been legally removed.
