Wow, this is hard to be PC....To a certain extent that's exactly what I was saying but i don't mean it as harsh as Mlytle makes it sound.
Joe, chill out I would expect a little more class from you. :D
My comments are more about the car that shows up completely under developed and beats a well developed car and does it on toyo's to boot is just wrong. Then put a decent built car with a driver that can't find an apex to save his/her butt and it still beats a well prepped and driven 240z you get the same result.(frustrated drivers) Add to that a well driven well prepped car on good tires and you have the recipe to kill a class.
Joe, that's not saying to much about the 240 driver if this actually happened. Could you be exaggurating a bit? I've seen good Z drivers and there is no way a poor to mediocare driver will win, unless it's a drag race.
I understand the frustration but I don't understand the abuse on the guys that have worked hard to create fix that will in the end make the class healthy for all and in the end will be the most cost effective for those using it. I know that you all think your gonna develop around it but your not. I estimated that 300lbs over 10 races will run you an extra 6000 bucks in tires brakes wear and tear on the car. To me looking at the big picture if I spent a grand to make the SIR work it would be a 5k savings over weight in the first season alone.
Joe don't castrate all of us because of a few that may have radical views or posts. This is not fair. Your right about the weight Joe & the money, but I guarantee I wouldn't be spending it for events in SCCA. As for the big picture I bet if you calculate the time and materials that they have testing these SIR's to date it would be a hell of a lot more than 1K. Just bring back the RP, reduce the size if need be, don't allow any beveling of the spacer plate, for 100 bucks. :023:
DJ we are gonna have to teach you how to use the quote feature cause that was hard to read.
