Originally Posted by
lateapex911
Why FWD?
While the actual act of driving the car thru the front wheels might, or might not, be entirely responsible for the cars deficits in lap times vis a vis equivalent RWD cars, we use it because it's a consistent and easy to identify trait. In other words, IF the real reason these cars are slower is the weight distribution, well fine. But the ITAC doesn't have that info. But the fact that FWD cars consistently have bad weight distribution helps the ITAC to adjust the process in a fair and transparent manner.
Do other cars that have crappy weight distribution get the dick sandwich? Yup. Oh well. But we need to use obvious "triggers", and the FWD spec is easy.
It's not perfect, and will never be, but it's better than classing two cars with equal specs other than driveline layouts at the same weight.
I think we just need to find appropriate "bogeys" for each class.
