Engine Cutting Off
I have an engine problem that's really got me stumped. My engine dies when making a right hand turn. It feels like your turning off the ignition. If I feather the throttle 1/4 or less it runs fine, but more throttle and it cut off. As soon as I straighten the wheel it runs normal. Also runs great when turning to the left.
This is on a 1994 Miata 1.8 engine.
I have checked the following:
Fuel pressure good.
No loose wires on engine.
No loose wires under the dash.
No wires touching the accelerator peddle or cable.
I have replaced:
Fuel pump.
Kill switch.
Engine computer.
Any ideas would be appreciated.
Thanks Vance
Had a Miata buddy up here with a similar-sounding problem. He replaced the entire engine wiring harness, firewall forward, and it fixed his issues. - GA
Regardless of fuel level I assume?
Yes, this happens when tank is full or less.
My data logging computer monitors battery voltage which is solid. I also monitor the fuel pressure between the regulator and fuel rail and it is steady.
I checked the tank baffle when I replaced the fuel pump and it was not moving.
I thought about replacing the wiring harness. Hope I don't have to do it.
Thanks Vance
I had a similar problem with a 1990 miata, left hand turns. Turns out the fuel filter was the cause, full of crap that blocked the flow. Replaced it and problem went away.
I took the throttle position sensor apart (destroyed it) and found a bad spot starting ar 1/4 throttle. Hope this is the problem. Bothers me it only shows up in right hand turns.
I also going to replace the fuel filter and going to clean all the ground connections and put star washer under them. After that I will go test at a local track.
Thanks to everyone for your help and suggestions.
Vance
