I need some help with what wire to pick up to log tps on the DL1.
Car is a 2nd gen rx7 s5 motor.
Thanks for the help!
Wes
Wes
Page Z-32 of the FSM. It's either pin 2F (G/R) or 2G (B/G) of the ECU - not sure which. One is the narrow-range TPS and the other is the full-range TPS. You should be able to tell which is which with a quick look at the throttle body.
Don't forget to set your calibration with the engine running... ;)
Marty thanks! I will take a look at that in the next few days.
Vaughan... you made me do a double take for a sec!
