Having a problem with the car pushing from Apex to Exit,The car turns in good. Cannot get on the gas.
Spring Rates
800R
600F
Koni Race
22mm F bar
24mmR bar
225-15 Toyo 888s [tire temp and preasures are good ,, My CRX is on 888s and dont have a problem dialing them in.
Complete Bushing kit
1/8 toe out Front
1/16 toe out rear. Possibly should be more agressive on the rear toe? Just dosnt rotate like the CRX
Camber is -3 front and -2.5 rear That will change from track to track
The suspension is not in Bump....
Ride height 5.5 in
the cross weights are at 50%
Iam at ITS weight
Have tried many different set ups with the same results
This was the first season with this car and not extremly happy with its performance
Everything else about the car is good Power/braking
Ok there is one thing that this car has and its a welded Diff...
Could this diff be the problem
I do have a LSD for 2011
Would like to here from other Del-Sol ITS owners
Fastist
