Fuel Injectors
I cannot locate anything in the GCR specifically concerning the replacement of Fuel Injectors. I assume that the rule which states that if the GCR does not state it it cannot be done. I assume then that you cannot replace stock Fuel Injectors with higher flow injectors since the specs would be different than OEM?
Originally Posted by
dickita15
correct.
Dan,
You don't need more fuel, trust me. You can't get enough air into that motor to take advantage of what you have already. Come down to the shop and I will show you the mapping on my car from the Haltech.
