I had someone tell me we can remove the double throttle butterflies and the daspot for better flow is that correct?
Also there quite a few air lines that need plugged when you disconnect the air pump and the two coming off the ait intake, like the five small lines under the manifold that come off the air intake and connect to several places like the two bolts with the bango connectors with the plastic lines coming of them. What should I worry about?
Thanks in advance
