The new Defnder data prompted me to pull this together. Consider it to be prelim. All data is from public sources I found on the net.
http://www.am-rennsport.com/HNR.html
Jim: I know that you put some time into gathering the information. Thanks very much. :happy204: Is there anyway that additional information can be added so that where there are values for different devices, we can see which might be better? I.E. for a particular measurement, are higher numbers better or are lower numbers better.
It would be nice to know what all the column headings were.
But this is a good start. Thanks, again for the effort.
Thanks Bill....... consider that to be a living document, it'll grow. I am sort of at the mercy of what is publicly available. The site below, that I also post on, has more info:
http://www.trackpedia.com/forums/showthread.php?t=4829
Lower is better on the numbers
According to your chart, the Hutchens Hybrid X has the best number?
I'm just learning to interpret the data, so I won't judge at this point. Also, missing data (keep in mind all I had were public sources) might show something else. The Nij is something to probably watch where available. That thread on Trackpedia has more info on what the parameters are what they mean.
I have added a fair amount of info and links on that Trackpedia page noted above that should help you understand the parameters.
