best locations for kill switch on an ITA EG... thoughts? I am guessing somewhere on the roll cage or rear tailgate.
Maybe the sunroof switch on the left side of the dashboard?
On our teg, its through the right side dash air bag "cover" on the car. Advantage is that nice and short wire runs and light weight. I hate it though cause when I get in the car, you can't really reach it from the drivers seat or when you get out too. Its probably the best deal but unless you got 4' arms, its a pain.....
Mine is on the passenger dash just above the glove box. The wires go straight down through the glove box, then out the back and under the dash with the rest fo the wires. I can't reach it while strapped in the car, but it's good access to the workers through the open passenger window (who would be using it anyway).
Victor
ITA 03
90 Integra
Put it some place where not only a corner worker can reach it, but you can too. I put mine right on the a-pillar tube of the rollcage, just to the left of the steering wheel. Just a weld a little tab to it for the mount. Easy access from outside the car, as well as from the drivers seat.
X3
^^^^^ x 5.
I HAD mine on the cowl, just in front of the windshield. I am usually alone when i race. I can't tell you how many times I sat on grid, just strapped in and discovered I had forgotten to turn the damn car on.
so I moved it, as described by Ruck.
shuolda done it years ago.:blink:
I gots mine right dar.
http://img2.putfile.com/main/9/25423361720.jpg
^^^ Yup, just like that.
A pillar... easy access for all involved!
http://www.izzyscustomcages.com/imag...n/P1010072.JPG
Must be a first gen RX7 thing to mount the switch on the cowl! I did the same thing on my first one, my second one was wired that way when I bought it, but I at least ran a second relayed switch that sat in the console so that I could turn it on/off while I was in the car
If you still have the stock key/ignition you can still turn the car off. On all my cars the switch has always been on the passenger side near the mirror. The only one that I put there was my current car all the previous cars the owners put it there on the other cars.
Any reason why not to put it there other then for it to be out of the way so that you can't bump it while getting in and out of the car or the window net catching on it?
I remember seeing exactly that... a SCCA legal kill switch on both driver and passenger side dash.
I think it's was on a 1992 Civic with a K20A2 swap running West Coast H0 honda Challenge... I think it was featured in the 2005 issue of Sports Compact
ahh... found it!
http://www.sportcompactcarweb.com/fe...20a/index.html
http://images.sportcompactcarweb.com...erior_view.jpg
http://images.sportcompactcarweb.com...utton_view.jpg
In regard to placement, have to add a +5 to the idea. However, I'd also like to add making sure that it is marked correctly and visibly from outside the car. If my fat butt has had to run 50 yds. in boots, carrying a 10# fire bottle (they actually weigh about 20) through a gravel trap on a 100* day to get to you, I'd like to be able to go STRAIGHT to the switch. After seeing your condition in the car (a couple of seconds), my next priority is the kill switch. Just my $0.02 worth.
Scott
Thank you for the advice everyone. Okay, I think we're putting the kill switch on the right hand side dashboard - 6 inches from the window opening marked with a kill switch sticker on the dasbboard and on the outside on the door just below and to the left of the passenger side mirror
