Calling all rules nerds,,,,,,
I have a few rules questions I want to throw out for feedback.....
1. Can I legally change the bolt pattern of my hubs via the use of spacers ( not saying that is a good idea, just asking )
2. If my car allows the rear tubes of the cage to go thru the back glass and the GCR allows rear bars to go thru bulkheads then can I do both? Any reason I can't modify or remove the enging cover if bars pass thru it?
3. Is any modification to the strut housing legal i.e. changing spindle height?
4. Is there any reason why an aluminum underbody plate or pan could not be used to "protect" the fuel lines?
5. If oil coolers can be added or subtracted could my oem cooler be deleted or moved from it's enging mounted setup to a remote setup?
