Originally Posted by
Grumpa
I probably should have thrown this out initially. I am running 13 x 6 rims in an effort to keep the cg as low as possible, so the tire size will be 215-225/45-50/13, depending on what the tire companies offer. I don't think Hankook offers a 13" and I'm pretty limited by Hoosier, Kuhmo, Yokohama, etc. I tried 14's, but had clearence issues that were remedied by a ride height increase which had a negative impact on the car's handling. The car is lined at 2000#, but it will require a 180# pilot to make weight and I'm not quite that svelte - fairly far from it in all honesty. The car is pretty good on tires with the setup that I have on it now, although I am going to test a lower-450/500-front rate spring with a higher-550/600 rear rate spring in an effort to get the car to rotate better.
