GCR states that the rotors must not be modified except for truing and such...
however no mention is made about the calipers... if i run the factory size and dimension rotors... am I allowed to use aftermarket calipers??
Thanks in advance,
Mike
Thanks in advance,
Mike
If it (the GCR) doesn't say you can.... you can't.
Actually, you can, as long as they are exactly the same as stock. See the replacement rule for exact details.
But....it is NOT a chance to change the metal or the piston size or anything...just an option to source the same part thru another channel.
