Hi all,
I have a track day coming up this weekend and any opinions/pointers regarding this are greatly appreciated.
Some background!
During my last HPDE I miss-shifted from 3rd to 2nd instead of 4th which over revved the engine to about 8k rpm. Once the session ended, I checked the cylinder compression and got the following reading 1: 190psi, 2: 195psi, 3: 190psi, 4: 195psi. Since the compression seemed ok and the spark plugs looked good, I took it back on the track for the last session and the car ran fine except that the exhaust sounded a bit different then normal. Since that day I didn’t really drive the car but just started and warmed it up to normal running temperature few time in the garage.
The problem!
Till last Friday the car was starting up just fine and I loaded it on the trailer to take it for tech inspection but when I tried to start it to take it off the trailer, it just wouldn’t fire up. There was partial combustion but it never fully started.
So last night I removed the spark plugs and found that all the plugs were black with carbon residue. I also checked the compression again on cold engine and the readings were as follows
cyl 1 - 180psi
cyl 2 - 200psi
cyl 3 - 195psi
cyl 4 - 200psi
Then I installed the spark plugs after cleaning and adjusting the gap. After this when I tried to fire up the car, it started up just fine and I had engine running for 10-15 mins. The idle was smooth but the engine was shaking a bit and I could hear a minor clicking sound coming from around the cylinder head.
Today morning started and warmed up the car for 10-15 mins again and then took out the plugs and observed that the cylinder 1 plug had carbon residue again whereas the other 3 were just fine. I tested the compression again since the engine was at normal running temperate and here are the results
cyl 1 - 130psi
cyl 2 - 190psi
cyl 3 - 195psi
cyl 4 - 190psi
So it looks like there is a compression leak from cylinder 1 and I think the exhaust valve might have gotten bent when I over revved as initially stated.
The question!
Is it safe to run the car in the next HPDE without fixing this as I don’t think I will get enough time to fix before the weekend? And if I do run it the way it is, what is the worst that can happen? Also, is my assumption valid that it most likely is the exhaust valve that is bent since there is carbon buildup on the spark plug?
Thanks in advance.
