Hi All, I am looking for a carb insulator from an old Omni. I have the 1.7 intake .they ran the Holley 5200. I want to know if the 2.2 had the same carb and did they use the carb adapter?? If so < i would like to buy one. thanks, Mike Ogren 352/796/1985 racingcarsrental.com
Mike: You're talking about the aluminum plate between the intake manifold and the carb, right? My '84 parts book calls out the same part number for both 1.7 and 2.2 engines.
Let me know, I may still have one extra.
Your a day late and a dollar short bill !! I already took care of it ... :D
No problem, Mike. How are you doing?
BTW, I'm chasing a charging circuit problem. When I turn on the master switch, I get 12.5 volts. Turn on the ignition, voltage drops to 11 volts. When I start the engine, the voltage remains the same, meaning that the battery is draining.
I have replaced the alternator, and the voltage regulator. I then checked the continuity of the wires from the field terminals on the alternator to the voltage regulator plug. One tested ok after moving the probe aroud a while, but I could not get any continuity on the other wire. So I am replacing the voltage regulator plug. Grounds are all good - brand new cables.
Any tips?
