The engine came out over the weekend, and the transmission is back off so I can reattach it properly. While the engine is out, the plans call for 1) removing the lower control arms and replacing the bushings with Polybushings, 2) refacing the flywheel, 3) dressing up the engine mounts, 4) replacing the altenator bushings, 5) removing the catalytic converter, 6) removeing the EGR valve, 7) renewing the brake calipers, 8) removing as much emission stuff as I can, 8) replacing the oil pan with one with baffles installed to control oil slosh in corners.
Can anybody think of anything else to do while the engine is out? That will not take all summer or cost more than the car!!!!!!
1) all bolts are loose, ready to come down
