Oooo! Oooo! Oooo! You guys are gonna hate me.
ITCS states:
- "The driver's seat (only) shall be replaced with a one-piece bucket-type race seat." Minimal limitations to its design. So, you can actually fab your own (witness some of those older Kirkey seats)
- GCR (SS cage rules) states: "The driver's seat shall be firmly mounted to the structure of the car."
- GCR (SS cage rules) further states: "In cars where the seat is upright, the back of the seat shall be firmly attached to the main roll hoop, or it's [sic] cross bracing." No limitations to this bracing.
You see where I'm going, right? C'mon, don't make me say it... [/b]
Yes, I know exactly where you're going... a chassis-stiffening seat structure.
But there is another way to peel this onion that will make your eyes water even more. IMHJ, the way the rules are written (or more importantly the way they are cross referenced), it may not even be permissible to use the SS cage ruleset to determine how to mount your IT seat, and it is definitely not required!
Let's look at the paragraph in the ITCS that points you at the SSCS cage requirements:
10. Safety
a. All cars shall have a roll cage installed. The cage shall meet GCR Section 9.4.2., requirements for Showroom Stock cage configuration, tubing size, and material, except as provided for in these rules.[/b]
Well, guess what? First, it doesn't say squat about the driver's seat - only cage config, tubing, and material are mentioned. And further, the driver's seat requirements are provided for in these (ITCS) rules... it's the paragraph that Greg quoted above, shown here in it's entirety:
a. The driver's seat (only) shall be replaced with a one-piece bucket-type race seat. Factory seat tracks/brackets may be modified, reinforced, and/or removed to facilitate replacement mountings provided they perform no other function. All other seats may be removed.[/b]
This paragraph provides all the rules you need to mount your IT driver's seat. Therefore, the SSCS seat requirements are null and void. And incidentally, in any case, the underlined part of the ITCS seat paragraph would seem to nullify any attempt to stiffen the chassis by building a 900 pound gorilla seat.
