Hey ITAC members,
On perusing the spec's for ITR I realized that all the BMW Z3's are classified with a 6-speed transmission. I've sent in a letter to the CRB to point out this error; however, I'm curious to see if the correct transmission and ratio's were used in classing the Z3. The proper transmission and ratio's can be found in the Touring rules. Thanks,
James
Letter IT-06-112.
Corrected and submitted to the CRB under errors and ommissions.
Thanks Andy,
So the correct transmission was used when classifing the Z3's?
James
James, if you are asking of the Z3 got extra weight because of a 6-speed, then no, it did not. The 6-speed spec was a simple transcription error of unknown origin.
Thanks Andy,
Just as I suspected, just looking for some confirmation. I was a little concerned that it was possible for a Z3 racer to be protested for not having the correct transmission, when it was truly the correct stock transmission.
