being that this is going to be my first ever experience on any of these tracks, i am just looking for some suggestions / opinions on the type of tires i should run, tire pressures, camber settings, things i should look out for, and if you guys know of any local places that sell these tires at relatively cheaper prices.
thanks for all the advice in advance.
Second on the Toyo RA-1's, they're a very forgiving tire that doesn't go soft when you run them hard. They also go through an amazing amount of heat cycles, many more than the Hoosier's, Kumho's, or Hankooks. While they may not be as fast they don't get as slow either when they go off. I've heard that you'll probably slow ~2 seconds when you pass the heat cycle limit. If you go to the Toyo dealer I think you'll find a racer/dealer in Castro-Valley. Size wise look for 245's as their the same width as 225 Hoosiers so you won't give anything up in terms of rubber. Good luck,
