Jason, it's going to be interesting getting to the bottom of WHY the pro motors make the hp they do.
If it's because the pro shops are going through hundreds of parts looking for the lightest one, then yes, just allowing that will save $. But...if it's because they go through hundreds of heads to find the ones that make 5 hp more because they flow better, then, no, that can't be designed in.
My friend who runs a Formula Continental (pre Z-tech) has an interesting story that relates to this issue with SM and pro-motors. It seems all of the run-offs and championships in FC have been won with one head. This head specs out fine as far as port size goes and a tech inspector wouldn't be able to tell why it wins all the big races. The reason why is that it's a factory reject. Now do you think your V8 jockey would be able to get the right kind of factory reject to make more power? No, only a pro shop with factory connections could go out in the scrap pile and look for the right kind of reject, they'd then magnaflux and inspect and machine, and ect. Untill they've got a class beating stock head. Same for all these reground stock cams that have filtered into the class. How'd Sunbelt et al. get hold of factory cam blanks with the stock part number on them? What are the tolerances for the stock cam profile and could you grind a cam that matches the best profile with in that tolerance? Normal production tolereances have lots of wiggle room in this respect, room that can be taken advantage of. Now you've got a good well season block, how square is it, how well are the cylinders located with respect to the crank pin? How straight are the main bearings aligned? Everything that's machined into a chunk of metal will change after a good number of heat and stress cycles. This is where a good blue-print can really make hidden hp. and these details the average may be able to cover, or they may not, in the end you'll still spend the same money as the pro-built motor, because they've developed the knoledge base to make the hp, or you'll be paying for the local shop to develop this same knoledge base. In the end though, I think a more open blue-print allowing motor rule will benefit SM. It'll make it marginally cheaper, but the motors are getting old and need going through and a no blue-printting rule no longer makes sense, especially for the 1.6l's.
