I am finally putting together a true gauge package on my car. I went with the larger diameter gauges for quick readability. My plan was to install them to the right of the OEM gauge cluster. In order to make them fit I will need to relocate the heater controls lower, and remove the OEM switch panel between the cluster and heater controls. I was hoping to fit them above the heater controls but it just won't work.
I do intend to keep the heater controls functional, as I use them regularly. Does anyone see a problem with this?
Found a picture of something similar (hope you don't mind Bildon). I intend to mount the heater controls either in the bottom of the large flat panel, or where the bottom switch panel is here.
http://www.bildon.com/pub/ITBGolf/in...tb55_dash5.jpg
I went with standard size gauges, I have no problem with reading them at all. I did however choose a silver background to make them visible in next to no light. The only thing I would have to do if I went for enduro would be to actually wire up the lighting for them since I neglected to do so for sprint racing. My gauges fit in my din pannel and I still have my heater control. I know some have removed the main cluster and installed their gauges there too.
I already have the guages, so I will be sticking with the large size. The tach and oil pressure will sit in the OEM cluster location. I just need to make some space for three guages. I am actually leaning towards keeping the controls in the same area, but mounting them in the flat panel so I can nudge them down a bit to make room.
To me it is obvious that there is no performance advantage being sought, but I would like some input from others.
I belive such modification in order to add the guages is legal.
Consider it done. Thanks :023:
