Anybody use or know someone that does use the Hyperco load centering spring perch on there IT car?
http://www.hypercoils.com/Products/Hyperco...ring-Perch.aspx
Jon
Jon
I looked into them, but determined that they would not fit onto my strut perches.
Quite ex$pen$ive too.
Formula Cars use them all the time...
Snapdragon Motorsports has an ITB BMW as well as a Formula Car. I know they use them on the formula car but not sure about the IT car. They are a supplier for Hypercoil so you might want to contact them for some further information.
http://www.snapdragonmotorsports.com
Raymond
PS: If you contact them let them know I gave em a plug ;)
I have been using them for several years on my Sports 2000. They really help reduce friction in the suspension -- you may find the shocks needs to be valved 20%stiffer to compensate for the friction that the springs impart upon the shaft seals. I think they really help cars in low-grip situations (like rain).
That said, I'm not sure they would benefit an IT car unless you've already reduced the suspension friction in obvious ways (no rubber/plastic pushings, only spherical bearings or roller bearings, high-quality shocks/struts.
