Online registration is now up and running in CFR.
Please visit the CFR website at www.cfrscca.org, for event information and the link to access the online registration system. We recommend you read the information posted on the web and setup your permanent number (if you have one) prior to entering the event.
We ask for your patience as we work through any issues with the system that may have been missed in testing. One issue that Hollywood was the first to find is that the system is providing mis-leading information regarding event payment. You should mail your check, with a copy of the confirmation, to the registrar. Mailing address is in the supps.
For those of you who haven't used this system in the past, you can login anytime and check current entries and make changes to your entry information before you get to the track. Which means some of you guys won't be holding up the lines adding crew and filling in blanks. :D
Thanks!
CFR Race Board
This absoutely ROCKS :happy204:
Thanks to everyone who made this happen. :023:
Online registration. Good work in putting everything together!
Wow, I've never been registered for an event this early before.
Good job.
I almost wish I was racing just so I could use it! :023:
Once again CFR has raised the bar for every other region. Well done.
good job CFR .registering was a breeze.
now if we can get FL region to follow suit. :happy204:
