While the trailing plugs do not work as much as the leading they can get real wet and not fire at all. Tom, it sounds like one rotor is flooded and not firing at all. Is that the first time that you ran it after installing the plugs? Check your firing order also, make sure nothing is crossed.
HMM ok I may have croosed something up. I looked is Haynes and factory service manual and I don't see anything on firing order other In haynes it of course it explans the T and L marks on the housing but on the next page it says "the boots of the leading (upper) spark plugs are Blue and the trailing(lower) spark plug are black." end of quote So maybe I have crossed wires. As I look at the Engine on the plug side. Upper left is T1 Upper Right T2 Lower left is L1 lower right is L2 I think. Is there a manual "Rotary for Dummies" ? probably I have crossed wires Actually on Saturday it Ran Fine but when missed fire started I may have crossed something looking for cause.
