I am building a new 89 325i racecar and want to make sure it can run in ITS as well as BMW CR and NASA Spec E30. I want to remove the whole sunroof "cartridge" - the part the sunroof slides back into over the back seat. Do you guys read the following ITS rule as allowing this (sunroof frame)?
Also, can the power steering pump and associated hoses be removed? I only saw a rule that said they could be replaced.
thanks,
bruce
f.Carpets,center consoles,floor mats,headliners,sun
roof liner and frame,dome lights,grab handles,and their
insulating,attaching or operating mechanisms may be
removed.Door interior trim panels may be replaced with
0.060 ” aluminum securely attached to the door..All other
interior trim panels,except the dashboard,may be removed.
Other than to provide for the installation of required safety
equipment or other authorized modifications,no other driver/
passenger compartment alterations or gutting are permitted.
The door window glass,window operating mechanism,and
