There should be no seems as this is full width and full length. one end will be under the cabinets and the other end by the ramp door I have planned to screw down underneath a strip of diamondplate. the edges I plan to screw down with thin strips of aluminum. Hopefully this will work.
Be careful. I used the BLT flooring in my previous trailer. It changes size by quite a lot with temperature changes. I retained it with stripes of etrack and other tiedowns and it only laid flat after that when the temperature was the same as when I laid it, with was in the early springtime. It also stains very easily if oil or transmission fluid sits on it.
