got my BSI bolt in camber plates(sorry bill..will upgrade to yours when available) today and am going to try and install this weekend. Any tricks,do's and dont's.
Can you measure caster at home? If you can then it is labor intensive, if not a good alignment shop or body shop is needed. You really need to get the caster right or you will fight the car. Example: my BSI weld in plates (16V Golf) took 12 hours to install with a alignment machine and a MIG. I ended up with exactly 4 deg positive caster on both sides and it has stayed that way for five years of racing.
Jon
thanks for the info -
