So, Im looking over the rules regarding suspension, and I noticed this:
"As of 1/1/03, external adjustments of shock control shall be limited to two (2)."
My question is, does that mean we can only have 2 settings on the shocks, i.e. Tokiko 5-way adjustables are illegal? I just want to be sure that Im interpreting the terminology correctly. Thanks!!
Jive
No, it means you can have two adjustments: typically compression and rebound. No high speed compression and low speed compression and high speed rebound and low speed rebound, etc.
Within those two allowed adjustments there are no limitations (e.g., it can have 238 positions...) - GA
Aha! Excellent. Thanks Greg!
I had interpretted it as Greg indicated.
However, I do agree the language is vague in communicating that point, enough so that despite my own view I asked the same clarifying question you did.
The vagueness could result in a couple conclusions.
