450# front springs, 350# rear springs, what are good settings for smooth tracks, bumpy tracks, autocross, towing? I assume full soft for towing. The car came with all 4 one full turn from full soft, using the low tech method (bounce the suspension by pushing down on each corner) the rear felt ok, but the front was bouncy, after putting all full stiff they are of course...stiff. But what is a good baseline for different scenerios? I believe the shocks are off the shelf so no revalving. (I didn't build the car)
First of all what car?
My 16V Golf has 450# front and 475# rear with a BSI rear bar and no front bar.
I have the double adjustables in front and the singles in the rear. The shock valving has evolved over time as the car got faster and my driving is getting better.
If they are off the shelf Koni yellows then set them to the middle and go run a track day and get tire temps. Shock settings will change with camber and toe settings, track conditions, air presures, so on, and so forth........I don't think one persons specific settings will work for your driving style. If your car is a A2 then I would tell you to first increase the rear spring rate. But that would work for my driving style. I raced with a guy that had a very similar car as mine, one big difference is he was running 1000# rear springs and 950# fronts on LEDA shocks on custom valving. Very fast car, sorry driver, the last two owners of the car have resprung it. It is all about your driving style.
When you have reached the point that they are all the way stiff then send them to Lee at Koni and have them revalved.
Seat time is the best money spent on a race car bar none.
My .02
Jon
A1 GTI is the car, just looking for a recommended starting point.
I think that, rather than looking for a recommendation, you'd be better off long-term by learning some things about how your particular package reacts.
Start with both ends full soft and run a session. Then, before the next session, set everything to full stiff. It might even be possible to have someone change them mid-session if you have a buddy on the pit wall.
Then, try front full stiff, rear full soft, and vice-versa (maybe on a different day by now). If you are like me, you might actually be able to feel the differences at this point. If you are particularly sensitive, you will then be able to make subsequently smaller adjustments and be able to feel them. I'm always amazed at drivers who can feel the results of really little changes since I just ain't that good.
What Kirk said + this >>> READ IT, LEARN IT, KNOW IT :D
Koni Road Race Setup Instructions
