Moves 5 gallons through an unleaded restrictor in less than a minute...
http://it2.evaluand.com/gti/images/dumpcan.jpg
"I'm a little tea-pot...."
[This message has been edited by JohnRW (edited March 08, 2005).]
That's not the MOST unkind thing that's been said about the shape of the nozzle to this point...
http://ITForum.ImprovedTouring.com/redface.gif
"Is that fuel can full or are you just happy to see me?"
Steve Linn
'92 ITA Sentra SE-R
www.indyscca.org
http://img.photobucket.com/albums/v3...n/SideSER2.jpg
LOL....... http://ITForum.ImprovedTouring.com/smile.gif
Phil Phillips
2004 Honda Challenge H3
NASA ECHC CHAMPION
www.philstireservice.com
You keep laughin' there, Phil - right up to the point that you see the business end of that thing coming at you in the side mirror at Summit.
LOL....That would be ok Kirk, as long as it stays attached to a gas dump can .... http://ITForum.ImprovedTouring.com/smile.gif
Phil Phillips
NASA ECHC CHAMPION
[This message has been edited by philstireservice (edited March 09, 2005).]
still laughing... http://ITForum.ImprovedTouring.com/smile.gif
Phil Phillips
NASA ECHC CHAMPION
Kirk,
Could you post pics/list of the parts you used and where you aquired them? What are you using for the vent hose connector? I'm assuming you cut a hole in the gas can and used some kind of threaded adaptor with a gasket. Then an elbow with the hose clamped. Beats the hell out of buying a expensive dump canister.
Tom
The key part is a 3/4 NPT poly "tank fitting" by Banjo Corp. You'll need to find a local dealer (try the Banjo web site) - mine was an agricultural fertilizer company.
They are supposed to make one with a Buna-N fuel-resistant gasket, but I couldn't find them locally and ended up with Viton seals which should be fine.
The rest of the parts are poly NPT-barb fittings from Home Despot.
Nice setup,
Just some free info,
I drill out the vent breather with a 3/8" drill bit on all my gas cans. By doing this, they will dump much faster too.
Nice setup Kirk! So that tube on the bottom is just a big vent?
so then what do you use to cap the bigger hole? Is it still small enough to fit under the cap that it comes with?Quote:
Originally posted by racer-025:
Nice setup,
http://www.swltech.net/gallery/
It works exactly like Big Boy dump cans. That tube is just a vent, the same size as the fuel outflow and on top of the column of fuel rather than at the bottom. You turn it over and no glugging or bubbling - the fuel just drains.
Kirk,
I don’t know if it would work for you, but I recently timed how long it takes me to dump 5 gallons (of diesel) through the “standard issue” US Army Fuel can using the available “nozzle” (Donkey D**K in military terms) that locks on the can. and it was about 30-35 seconds. These parts are all available at any Army/Navy surplus store and the new cans are plastic, not metal.
Now obviously this vehicle has no unleaded restrictor and I don’t know anything about how much better or worse diesel would flow than gasoline but I thought that 30-35 seconds was impressive.
Just a casual observation at work this week. (Yea I can’t wait to get back on the track)
Matt Bal
This is the best I have found.
http://www.hunsakersports.com/shop/
Kirk,
Years ago, when I first got involved in endurance racing (Entropy Racing), the team owner, Charlie Greenhouse, had something that looked almost exactly like that. They worked very well. I've seen others that have ball valves on both the fill and vent lines, which lets you store fuel in them. Also, since none of the cars we ran were still street legal, we removed the restrictor from the filler neck, which allowed for a larger fill hose. I don't remember the exact fill time, but I believe it was on the order of 30 seconds.
SCCA 279608
For those that care, they are also illegal at NASA sanctioend enduros http://ITForum.ImprovedTouring.com/smile.gifQuote:
Marcus
Why are they illegal??? http://ITForum.ImprovedTouring.com/confused.gifQuote:
Marcus
SCCA 279608
NASA enduro rules limit you to 2 5 gallon containers. Those were advertised at holding 6+ gallons, in addition to pouring faster. Jerry Kunzman declared them illegal following last year's 25 hour event. I can't find a refrence ot it in the rule book though...
Marcus
There's a reason why I pay to be on this site! I was just going to buy four of those jugs for my "enduro" car that I'm planning on running at the 25 hour. The Acura team put those jugs to good use last year. Marcus I owe you a beer.
