The ITB bustangs from 79-93 can have the 2.3L engine in the lx, but my question is can I run an SVO mustang which is the turbocharged 2.3L?
I might be wrong, but I don't believe that forced induction of any type is allowed in IT classes.
In a word, no.
-Marcello Canitano
www.SilverHorseRacing.com
im a newb and i thought they werent but i wasnt totally sure... i am pretty sure u can use forced induction though in improved touring... arent there turbo RX7s?
No forced induction of any kind is allowed in IT...even "Ram Air".
The RX-7 is allowed with normal aspiration, only.
Bill
[This message has been edited by BornForFords (edited October 01, 2003).]
i stand corrected... would taking out a healight and putting the filer where the light was count as ram air... im guessing yes
You guess right. But even if it wasn't "ram air," you cannot remove a headlight in IT.
Regards.
You might be able to run in ITE, as I've seen other turbo based cars run.
Actually, using an opening from a headlight does not constitute "ram air", as defined in the GCR, unless the opening at the headlight has an "...extension onto the airstream". Just had to add that, Joe, since I'd "been there, done that".
Bill
I knew you would chime in, Bill!
