ITA 240SX ring and pinion
Hopefully someone can help... here's the situation:
I have prepared an ITA 240SX and will be going through the driver schools next month(northern Ohio racing season doesn't start very early) and I would like to go to a higher final drive ratio.
I know that my car has an R200 ring gear (200mm?) and I think that older pathfinders have the same gear in the front differential, and they have a 4.375 or a 4.625 ratio.
Does anyone know for sure if they will fit into my car's rear-end, or if the gears from any other readily available junk-yard find will fit... I don't want to have to spend $650 on a set of NISMO gears.
ITA 240SX #76
Rookie Year!
