Originally posted by terry:
Thanks for the info. still would like to know why there is a difference on which end to place the heavier springs.
Weight transfer. More spring = more weight transferred. Theoretically, more weight transerred = less grip (two equally loaded tires have more lateral grip than one tire with twice as much load, because F=uN is not linear for a car tire), however, things like camber thrust and geometry change with suspension deflection affect each tire's available grip in conjunction with the vertical load. Weight transfer therefore affects the relationship between over and understeer. So, you eventually arrive at a combination of spring rates that preserves the contact patch as much as possible by reducing roll without skating across road imperfections, and that gives you the weight transfer necessary at each end to balance the car wrt understeer or oversteer for a steady state corner.
