Link to ebay
i am familiar with this car. it spun coming out of 10 at summit. tagged the inside wall with the front end. may be rebuildable, if it is, the cage alone would be worth it. mitch piper built a beautiful cage in this car.
marshall
What's the rear in it (LSD, size, ratio)? A good friend in CT just picked up a sweet '84 e30 with a bum camshaft. Neither of us knows too much about BMWs, yet... and I don't even have my ITCS with me this week. How many of the parts from the wrecked '89 could be used on the '84? How about for an IT build? Is there an IT spec line that includes both '84 and '89? What from the '89 wouldn't fly on the '84 shell? TIA.
None!!!Quote:
Originally posted by Eric Parham:
What's the rear in it (LSD, size, ratio)? A good friend in CT just picked up a sweet '84 e30 with a bum camshaft. Neither of us knows too much about BMWs, yet... and I don't even have my ITCS with me this week. How many of the parts from the wrecked '89 could be used on the '84? How about for an IT build? Is there an IT spec line that includes both '84 and '89? What from the '89 wouldn't fly on the '84 shell? TIA. [email protected]
To different spec lines, in fact, to different classes. The 325i wasn't produced until 87. The 84 was either a 318 ITB or a 325, 325e ITA.
Thanks. I know what a "325e" is (different economy-type engine), but what's the difference between a "325" and a "325i"? I thought the "i" just stood for "(fuel) injection"...?
[This message has been edited by Eric Parham (edited February 05, 2004).]
there are three variations of the "325" there are the "e" , the plain vanila 325, and the "i". as said, the "i" was not available 'till '87.
the earlier "e" cars were 6 cylinder, 5 bearing camshaft, small intake/port/exhaust/2.5 (i think) t about 122hp. the plain vanila "325" was, i think, available in 86-87 and was an "e" bottom end (2.7) with the "i" big valve/port head but the smaller "e" intake and was rated at about 128hp. the "i" was the big valve/port/exhaust/7 bearing cam motor making 168 hp. the GCR specs two of the cars, the 325 as an ITA car with 2.7 motor only but with small valve head, and the "i" as ITS.
confusing????
Chuck Baader
SEDIV ITS #36 E30 BMW
Alabama Region Assistant Race Chair, Divisional Registrar
325,325e,325es (2.7) are all the same car the letters after are just trim levels
The 325,325e,325es all have a 2.7 liter crank the diff. being that the ETA engine has a 81mm crank and 84 mm bore.
To as the "I" engines have a 74mm crank and 84mm bore
the ETA engines all had the same head and block unless it's an 88 and then it changes up a little..... the 88 has lower compression but better flow for a little increase in horsepower....
the real kicker is the ETA's way of developing torque... with chip and free flow exhaust it will crank out 210 ft lbs
it only has a usable rpm though of up to about 5300 due to the ETA cam won't produce anymore.....
I'm building an ITa 325e right now and I just ordered a 3.73lsd rear and a few other bit's....
want to know something even cooler is that every one uses the 524td crank for the "I" engine and then bores it out to have a 2.7l "I" powerhouse,.... but I just found a "Lincoln Mark XII" with a BMW turbo diesel that has a forged 81mm(2.7l) crank....
these cars can be quite a trip
Chris Dehart
88 635csi
85 325e ITa (soon to be)
blustl(dot)com
chris...please e-mail me, [email protected] your web link did not work. chuck
Does anyone know if this car is still available?
Auction ended with no bids and I don't know how to contact the seller. Does anyone know the Seller or their contact info?
TED
Went back and checked the link...e-mail address on ebay was [email protected]--good luck. chuck
