What spring rates are people running on their E30 325's? I am running 500# in the front and 600# in the rear. Still getting quite a bit of roll.
I'm at 450 front and 650 rear. I have a 22mm sway bar upfront and the stock in the rear.(only reason I have the stock sway bar in the rear so I don't have to jack the car real high to get the rear wheel off of the ground) To decrease roll, welding tabs to the strut to alow the use of the M3 endlinks made a big difference. I started out with a 19mm sway bar on the rear, but it made it impossible to put power to the wheels when coming off of a corner.
Are you running a wing? I am running 25mm in front and 22mm in the rear.
Not legal, not functional(except as a parachute)Quote:
[This message has been edited by zracer22 (edited April 30, 2003).]
Didnt know that a wing wasnt legal in ITS.
700 front, 575 rear, no rear sway bar connected, m3 end links on front struts, advanced design dampers.
no wing... http://Forums.ImprovedTouring.com/it/smile.gif
marshall
Wow Marshall, that is an interesting setup. What size sway bar is in the front?
Jeff
sorry, a little slow on the reply...
to tell you the truth, don't know the dimension off hand. it is an eibach adjustable that i run on the soft setting. i don't seem to get much roll and the car is very neutral. ride high is minimum up front and about 1 inch above min in the rear.
stiff front, softer rear springs and no rear sway bar seemed to be the standard setup for the fast e30's that raced in the marrs series. i looked at the other setups here on the list and thought they were all "interesting...". guess there is more than one way to skin this cat... http://Forums.ImprovedTouring.com/it/smile.gif
marshall
Marshall,I agree, the E30 setups described on this list were interesting. Your setup is very much like what I had on my E30, only your spring rates are a bit softer.
ok bruce, i'll bite...
how much is "a bit"?
marshall
Here you go, 850 front/600 rear with LSD; 850 front/650 rear with a welded diff. RD sway bar in the front on softest setting mounted to the control arms, no rear bar.
Actually the settings are very close. Your getting more leverage with the front sway bar mounted to the struts, so the fronts would be closer than the spring rates suggest.
now that i think about it, my fronts may be 750. our setups were pretty close.
thanks!
