Does anyone run with a rear sway bar in their 2nd gen RX7? If so, is it stock or after market? what front bar and what spring rates front and back?
B
B
I don't think that this is an ideal setup, but it works well for me:
I run no rear bar, a Suspension Techniques adjustable up front (get the adjustable links!), 375 front springs and 275 rears.
Your mileage may vary, depending on what tracks you run.
No rear bar.
Some sort of adjustable bar up front, I have a Speedway Engineering splined bar.
Depending on if your shocks will handle the rate, 450 lb springs up front (some guys run up to 500 here in SeDiv), and 275-300 in the rear. You may have to compromise the rate if they overpower your shocks, or have the shocks revalved if possible.
Chris Wire
Team Wire Racing
ITS Mazda RX7 #35
