Strut spacers/Lower front/Ackerman improvement
1st gen RX-7 Strut spacers
When you folks procured Strut spacers & followed the SELLERS instructions to the LETER what issues surfaced ? Did the bolts that were provided fit per the sellers instructions ? Were you required to re-drill the holes larger than the sellers instructions ? Did you grind the holes larger between the holes so that the provided bolts would fit ?
If you measured the strut & or steering arm hole center distance what was the dimension ?
If you measured the strut spacer hole center distance what was the dimension ?
Thank you
