Hello all. I am going to attempt a rebuild on a clutch type rear diff (can't afford a Torsen!). As I just tore one apart, I am in the process of assembling the clutch pack. Any suggestions with clearances (such as using all oversize friction discs), or should I just follow the factory specs?
Any help would be most appreciated. Gotta get this part done so I can order some 4.8 gears from Mazdamotorsports!!
Jack
